ASSEMBLY ESSENTIALS
InterTech Development Company’s deep bench of test engineering talent has been helping companies develop new products in record time, as well as helping manufacturers of leak-sensitive products triple+ production output.
Get to know InterTech’s best-in-class patented technology:
The InterTech Universal Leak Tester –
-fully automatic set up requires the input of only 2 numbers: test pressure and leak limit
-leak tests families of parts ranging in volumes from several cubic centimeters to 10 liters or more with zero set up time
-leak tests in the range of 1 sccm or higher depending on specific application requirements
-test pressure ranges of 2kPa (0.3 psig) to 200 kPa (29 psig) are standard
-features an INTERTECH EARLY PASS OPTION™ for even faster test cycle times
-manual regulator is available as a lower cost option
InterTech has developed methods to speed leak testing up to 50%, in many applications. This proven technology has put numerous customers’ leak testing processes in the fast lane and eliminated production bottlenecks worldwide.
InterTech Development Company is ready to help your company achieve the highest leak and functional test standards and significantly impact your bottom line.
Schedule an appointment to discuss your specific testing application challenges.
Superior patented mass flow sensors combined with optimized circuit designs and fixtures eliminate the errors inherent in pressure test methods.
Unlimited combinations of testing: flow; leak; burst; pressure; temperature; creep; and more.
Documented 97% reduction in leak test cycle times.
All testing is 21 CFR Part 11 data integrity compliant.
Ethernet IP Capable for seamless integration with all plant quality assurance systems
7401 N. Linder Avenue
Skokie, IL 60077
847-679-3377
