ADVERTISEMENT
LEMAX mini vacuum pump guarantees value addition for robotic vacuum handling applications
The LEMAX mini vacuum pump fulfills vacuum handling needs through its lean design, air saving technology, and faster evacuation time. In comparison to traditional solutions for high-speed vacuum handling applications, LEMAX comes in a single block with all integrated functions while offering the possibility to customize the module to application demands. LEMAX’s intelligent pressure regulation and air saving control results in substantial energy savings compared to a traditional vacuum generator.
The LEMAX mini vacuum pump integrates all necessary functions such as electro pilots, valves both vacuum and blow-off, silencer, and anti-return valve, allowing the user to save time in identifying, selecting and installing several modules to suit the application demands.
Thanks to its lean design combined with two integrated M8 connections, users can plug in and start the operation while eliminating the various steps of mounting and cabling. This is useful not only for the OEMs in packaging and plastic molding industry but also to end-users, saving them time and procurement costs.
The analogue output of the vacuum switch with a digital display screen allows for easy adjustment and usage of the module. Unlike traditional regulating pumps, the LEMAX automatically detects the porous nature of the product surface and optimizes vacuum generation to offer the ideal vacuum output required for the application. This unique feature allows the user to anticipate any leaks in the application and fix the errors to ensure optimum efficiency and energy savings.
COVAL Vacuum Technology, Inc.
901-100 Jones Franklin Rd
Raleigh, NC 27606
Tel: (919) 233-4855
Fax: (919) 233-4854
contact@coval.com
www.coval-inc.com
Motor vehicle, Product, Font, Line
Scroll to
read full story
TOC
ASSEMBLY MARCH EDITION
