We place productivity and cost-effectiveness first for our customers: IPR’s 7th axes reliably and efficiently extend the working ranges of industrial robots in all industries – around the clock, seven days a week.
Whether small cobot, medium industrial robot or large heavy-duty robot – IPR has the right robot travel unit (RTU) solution for every application. Each axis is specifically tailored to your requirements and convinces with high quality, extreme load capacity and long service life.
Not only do we have RTU’s made out of steel or concrete but also axes which combine the best of two worlds: our hybrid axes. It combines both materials. Double steel profiles offer high stability which allows for a very high load-bearing capacity. The cast composite concrete on the other hand ensures lower vibrations and almost completely eliminates sound emissions. The 7th hybrid axes are also suitable for heavy-duty robots and have a payload of up to 11 023 lbs. Installation can be done quickly and easily thanks to the flexible floor mounting elements.
We will advise you personally concerning your specific application – we look forward to hearing from you!
More about our 7th hybrid axes: https://www.iprrobotics.com/category/7th-axes-for-robots-us/7th-axes-hybrid-us/
50775 Wing Drive
Shelby Township
MI 48315, USA T +1 248 556-7556
F +1 248 556-7560
sales@iprrobotics.com
