ADVERTISEMENT
Gain Control Over Your Manufacturing Process
Including Orbitform’s Process Intelligence Packages will improve quality and reduce scrap on forming, riveting, and assembly equipment.
Monitoring Packages
Force – Internal mounted load cell package provides force monitoring of the process as the head advances to process the workpiece.
Distance – Internal mounted LVDT package provides stroke monitoring of the head as it advances to process the workpiece.
Pre-Form Stack up Height Verification – Internal mounted LVDT and load cell packages, along with a programmable height sensing pressure pad, are used in conjunction to validate the pre-form stick-out height of the workpiece.
Detecting Workpiece Presence – Using the same machine set-up as “force monitoring” or “pre-form stack-up height” condition as described above, the presence of the workpiece can be detected every cycle.
Multiple Z-Axis Forming Positions – Orbitform’s Servo Z-axis control package and our Servo Riveters provide the capability to process workpieces at different height positions.
Control Packages
Form to a Force – Internal mounted load cell package, this feature can complete the process cycle upon achieving a set process force.
Form to a Distance - Internal mounted LVDT package, this feature provides the capability to complete the process cycle upon achieving a set advanced position of the head.
Form to a “Form Collapse” – Internal mounted load cell and LVDT packages, along with our programmable height sensing pressure pad and motor clutch/brake package; upon tooling contact of the workpiece during low pressure or low-speed head advancement, this position becomes “0”, and then the head advances to the set “form collapse” position and then retracts.
More information included in our blog article.
Scroll to
read full story
TOC
ASSEMBLY MARCH EDITION
