PRODUCT SPOTLIGHT
This special advertising section is your opportunity to quickly review assembly equipment, tools, components and services that you can use to make your product assembly operations more productive and profitable.
The RACO LM Series is a lightweight positioning actuator, which can be easily configured into a wide variety of multiple axis motion systems. The LM is engineered for a load capacity of 800 lbs., speeds up to 200 inches per second, and a stroke range of 20 feet with a single extrusion.
RACO International, LP
(412) 835-5744
(412) 835-0338
Toll Free: (888) 289-7226
raco@racointernational.com
www.racointernational.com
LM Series Actuator
The GVMAXHD is a leader in its field with advanced communication through IO-link technology. The configuration and diagnostics have been simplified through NFC technology for ease of use, and the integrated Air Saving Control (ACS) system saves you energy.  It has excellent durability, power, and performance for all your needs.
COVAL Vacuum Technology
(919) 233-4855
info@coval.com
https://www.coval-inc.com/
The Vacuum Pump That Does It All
February 2022
TOC
