ASSEMBLY ESSENTIALS
SPIROL’s Engineered Fasteners and Precision Shims have been used in a wide range of surgical, diagnostic, and orthopedic medical devices for decades. We understand the intricacies of the medical industry and have the technology, expertise, and
quality to provide superior products and services to meet your needs.
Even though they tend to be the smallest components within the medical assembly, fasteners are usually the most important element of the design as they literally hold the entire unit together and enable it to function as desired. The correct fasteners ensure that your device goes together and stays together for the intended life of the assembly!
SPIROL is a technical resource that provides high quality components that improve the quality of your assembly, extend the life of your products and reduce your manufacturing costs. We are the leading global manufacturer of engineered fasteners, installation machines, and parts feeding equipment producing over two billion components annually including: Coiled Spring Pins, Slotted Spring Pins, Solid Pins, Dowel Bushings, Spring Alignment Dowels, Ground Hollow Dowels, Spacers, Compression Limiters, Threaded Inserts for Plastics, Disc Springs, Precision Shims, Laminated Shims, Thrust Washers, Fastener Installation Systems and Parts Feeding Equipment.
In addition to high quality products, SPIROL has Application Engineers throughout the world to assist you in your designs, supported by state-of-the-art manufacturing centers and global stocking facilities to simplify the logistics of delivering your product. By partnering with our experienced, Application Engineers in the design stage of your next project, SPIROL will not only help select the most appropriate Engineered Fastener, but we will also make the critical recommendations for the interface between our product and your assembly, and ensure both your technical and commercial requirements are satisfied.
Contact SPIROL today for technical support!
ESSENTIALS
Scroll to
read full story
