MEDICAL REVIEW
CONTACT
Austin
The Right Robot for the Job
John Sprovieri // Editor In Chief // sprovierij&bnpmedia.com
Epson’s user-friendly RC+ programming environment simplified the job of programming more than 200 robots. Photo courtesy Epson Robots
MEDICAL PRODUCTS
“Always use the right tool for the job.” The old adage is applicable whether you’re talking about a hand tool or something as sophisticated as an industrial robot.
When putting together an automated assembly line for a medical device manufacturer, systems integrator Automationnth faced conflicting requirements. Some operations required a high degree of precision; others simply needed speed. Picking the right robot for each task saved the customer money without compromising performance.
“When manufacturers come to us with automation needs, it’s important for us to deeply understand their strategy and requirements,” says Greg Young, vice president of business administration at Automationnth, which has offices in LaVergne, TN, and Poway, CA. “They could be transitioning from manual production to automation, or they might need to scale quickly. We help them go from a blank sheet of paper to complex automated assembly by working together to find the best solution that meets their long-term objectives. We also help maintain that equipment after it’s in production.”
Founded in 1999, Automationnth has established itself as a market expert in medical device assembly applications.
Zimmer Group offers a variety of products for the medical industry, such as electric long stroke-,  or small electrical grippers, swivel units etc. Our products are IP64 rated and sealed,  IO-link ready and are the most cost-efficient ones in the market for a reliable manufacturing process. Click here for application examples.
Zimmer Group US, Inc.
828 855 9722
info.us@zimmer-group.com
www.zimmer-group.com
Zimmer Group – strong partner in the medical and pharmaceutical industry
“During one of our consultations with a medical device company, we came across a unique and challenging manufacturing problem,” says Jeff Buck, vice president of engineering at Automationnth. “Not only did we need to provide high-precision and high-performance robots on the front of the line, but we also needed time and cost-efficient robots on the end of the line.”
Precision Where It Counts
For Automationnth, Epson was a natural choice to meet all the needs of this assembly system. An Epson customer since 2017 and a member of Epson’s AutomateElite authorized system integrator program, Automationnth knew the robot maker offered a wide range of products for small-parts assembly.
Pfeiffer Vacuum offers different technologies for leak testing medical devices that are used to transport fluids or are directly implanted inside the human body. For products that need water tightness our Micro-Flow technology delivers fast and reliable air leak testing with reduced temperature sensitivity. For more demanding applications, our helium and hydrogen leak detectors are the perfect solution for hermetically sealed, implanted objects.
Pfeiffer Vacuum, Inc
Phone: 800-248-8254
contact@pfeiffer-vacuum.com
www.pfeiffer-vacuum.com
Leak Detection for Medical Devices
Flexbase, from Automationnth is a configurable, modular platform for automation. It enables manufacturers to standardize production equipment, simplify engineering and maintenance, and adapt quickly to changing needs. Photo courtesy Epson Robots
“A particular application that we developed for this customer required super high precision. We were looking for a robot that had ultra-high precision capabilities,” says Buck. “We found the Epson G-Series, and that’s why we picked Epson.”
Epson G-Series SCARA robots feature a high-rigidity arm design that delivers high speed, high precision and low vibration. The line-up offers a maximum reach of 175 to 1,000 millimeters and a maximum payload of 1 to 20 kilograms. The robot can perform a standard pick-and-place move—1 inch up, 12 inches across and 1 inch down—in just 0.29 second.
“With the G-Series, we were able to provide vision feedback to provide offset settings back to the robot,” says Buck. “This helped us establish an industry standard by which Epson robots are now widely used across many key life sciences manufacturers.”
ACE damping solutions quickly decelerate moving loads without damaging impacts. Our shock absorbers assist with slowing down and stopping functions, providing a quick and quiet stopping on machines. Stainless steel options are available for areas that need to be sterile and remain free from dust and debris.
ACE Controls
800-521-3320
shocks@acecontrols.com
https://www.acecontrols.com/
Provide safe, high quality care with ACE
Automationnth created a feeding system that used Epson G-Series SCARA robots to handle components that were barely visible to the human eye. Photo courtesy Epson Robots
An on-board I/O communications port adds to the all-in-one functionality. This provides a direct connection to the controller and includes power for the end-of-arm tooling, making it easier to connect cables to the end effector and supply power to it.
For applications requiring vision, the robot is already equipped to seamlessly integrate with an object-based, point-and-click interface for vision guidance. Using the integrated vision system allows all development to be done from one environment, thus reducing overall development and configuration time.
With reach distances of 400 and 600 millimeters, the T-Series can handle payloads of 3 and 6 kilograms, respectively.
Using a variety of automation equipment enabled Automationnth engineers to deliver the best combination of functionality and price.
“For the scope of this program, we were able to easily install a range of Epson robots—18 from the G-Series and 21 from the T-Series for each line. With six lines altogether, that’s 234 robots,” shares Young.
Programming all those robots could have been a chore, but Epson’s user-friendly RC+ programming environment made the job easy. The software allows all components to communicate on a single platform.
The FEC Micro-Nutrunner (On the AFC3000 series platform), offers the following features:  Multi-spindle configuration\sequencing, fieldbus I/O interfaces, torque/angle control methods, fastening result curve and data handling, integrated torque transducer and angle feedback providing highly accurate closed-loop control of the fastening process at very low torque (0.8Nm & 2.4Nm tool sizes).
FEC Automation Systems
(586) 580-2622
sales@fec-usa.com
www.fec-usa.com
FEC Micro-Nutrunner
For this particular application, the final product was the size a quarter. Its individual components were very small, indeed. The parts had insertion tolerances of 20 microns in the X and Y axes and 1.5 degrees of angular rotation. The robot would need to move with an accuracy of ±5 microns.
Automationnth created a parts feeding system that used Epson G-Series robots to identify and handle different components that were barely visible to the human eye.
The company also employed its Flexbase configurable, modular platform for automation. Flexbase enables manufacturers to standardize production equipment, simplify engineering and maintenance, and adapt quickly to changing production requirements. It also provides a lower-risk path to transition manual processes to semiautomatic or fully automated processes. Flexbase can be used for a variety of processes including assembly, sorting, testing, handling, fastening and joining.
Available in standard 4- or 6-foot-wide models, Flexbase can be configured as a standalone automated workstation or linked together to quickly create a complete production line. Optional conveyors can be configured with over-under pallet recirculation.
Performance Feeders Inc. fabricates high quality parts feeding systems designed to support system operator safety in the manufacturing environments while orienting medical products for assembly. Our complete line of peripheral components, such as the double panel sound enclosure, integrated with medical grade assembly equipment, create comprehensive parts feeding solutions that meet the safety standards required by our customers.
Performance Feeders, Inc.
813-855-2685
Sales@PerformanceFeeders.com
www.performancefeeders.com
Sound Solutions for Safe Medical Product Assembly
Flexbase is ISO 6 compliant and can be FDA validated with a documentation package. It has a maximum height of 7 feet, 6 inches to fit through a standard 8-foot doorway and includes built-in levelers. It is also ergonomically designed to accommodate a standing or sitting operator.
For this assembly, Automationnth needed to pick up components from various feeding systems, including a reel, a feeder bay and a tray. The parts would then be inserted into the assembly, explains Buck.
Simplicity on the Back End
For processes at the back end of the assembly line, which did not require as much precision, Automationnth integrated Epson’s T-Series All-in-One SCARAs, which offer industrial performance at a more cost-effective price.
Priced 30 to 50 percent less than conventional SCARAs, these compact robots are positioned to compete head-to-head with Cartesian robots.
The controller is built into the robot’s base, so there’s no need for a separate control cabinet or control box. There are no cables to run from the controller to the robot. A short cable duct on top of the robot also contributes to the overall compactness.
Motion Index Drives precision link conveyors are made for each application, manufactured with high strength aluminum extrusion, and custom modification for clean room requirements. Our conveyors deliver high accuracies of +/-0.06mm (+/-0.002") at each link position. All mechanical components in oil are sealed as a standard requiring no maintenance.
Motion Index Drives
877-978-1830
info@mid.us.com
www.motionindexdrives.com
Precision Link Conveyors and Medical Manufacturing
Marposs’ patented Dosaset solvent dispensing system eases the bonding process for joining plastic (polyvinyl chloride or PVC) components, tubes and joints. Continuous dispensing and distribution of cyclohexanone or similar solvents with automatic control of the solvent level to eliminate clogging issues for improved bonding operations.
Marposs Corporation
(248) 370-0404
marposs@us.marposs.com
https://www.marposs.com
Solvent Dispensing System
With the controller built in, setup and deployment are faster and easier. To set up the T3, engineers simply mount the robot to a tabletop, attach the end-of-arm tool, and plug it in. After programming the robot through an intuitive user interface, the robot is ready for work.
“It allowed us to interface with the Epson robots using a template code that that we developed,” says Buck.
Ultimately, the medical device manufacturer was pleased with the automated production line, which provided better quality and faster cycle time than manual assembly.
“Our customer is very happy because they were able to successfully execute one of the fastest production ramps the industry has seen,” says Young. “They are now producing millions of units per year, while also improving their yield and product quality. This also resulted in less product warranty exposure.”
Our dosing technology enables the process-safe filling of viscous, shear-sensitive, or abrasive products and so-called semi-solids. It is perfectly suited, for example, for dermal fillers such as hyaluronic acid or liposome-based depot drugs.
ViscoTec America Inc.
770-422-4281
sales@viscotec-america.com
https://www.viscotec.de/en/applications/medical-technology/
Process-reliable filling of high-viscosity products in medical technology
June 2022
Scroll to
read full article
TOC
