ASSEMBLY ESSENTIALS
ATC MX has also worked in several large projects refurbishing equipment originally built in Tennessee and installed in Mexico, taking advantage of local personnel to easily work at customer facilities with equipment availability restrictions such as weekends and second or third shifts.
ATC MX has developed strong relationships with local suppliers including Rockwell, Siemens, Keyence, Cognex, Festo, SMC, Rexroth, etc. These relationships allow ATC MX to improve delivery times, provide lower costs, and offer the best technical solution to our customers.
ATC MX’s Team Structure is a big differentiator from other automation companies. Our customers believe this has set us apart and contributed to our success. ATC MX Team Structure mirrors that of ATC Cookeville. The team structure allows the Business Unit Manager (Project Manager) easier and faster access to resources since all the technical areas including Mechanical/Electrical Engineering, Controls and Assembly due to direct reporting.
ATC MX has the full support of the Cookeville campus. Collectively providing support during project execution, sharing engineering knowledge databases, and adding additional resources when the project schedule demands. The collaboration has allowed for Cookeville resources to travel to ATC Mexico to provide support as well as Mexico resources to travel to Cookeville for additional support.
If you would like more information about the ATC MX facility, please contact query@atcautomation.com
Located in Monterrey, Nuevo Leon at “Milenium Industrial Park”, ATC Automation Mexico provides assembly and test solutions to companies located in Mexico. ATC offers full design and build capabilities using local resources to support these diverse companies comprised of the Transportation, Medical, Consumer & Energy market segments. The technical resources at the Mexico facility have been trained at our Cookeville TN facilities ensuring that the same standard of quality is maintained regardless of which build facility is used.
The ATC combined install base in Mexico is comprised of more than 60 projects. These projects mainly reside in the following industrial areas: Monterrey, Chihuahua, Tijuana, Coahuila, Tamaulipas, SLP, Guanajuato and Aguascalientes. Supporting the install base ATC MX has regionally located service engineers for fast response to service and support issues.
ATC MX also supports large projects executed in Cookeville, TN, for Mexico customers, by being involved in the early engineering stages and sending controls engineers to Cookeville for the final debugging process and run-off with customer. This strategy gives ATC Automation the ability to support large projects installed in Mexico using local resources, giving the advantage of quicker response, easier communication, lower costs in the post-sale stage, and excellent technical knowledge of the project.
Iridium #5012 Parque Industrial Milenium
ESSENTIALS
