ASSEMBLY ESSENTIALS
As many manufacturers transition to autonomous assembly systems, dispensing robots are a cost-effective, efficient choice that can be fully customized to a company’s unique process. Fisnar benchtop robots can easily update your manual dispensing to an automated system, saving money, waste, time, and labor. Benchtop robots are available in 3, 4, or 5-axis models.
If preserving your existing assembly line is important, Fisnar assembly line robotic systems are a great choice that can easily integrate with in-line industrial automation. The systems have axes above the application, making them ideal for large dispensing applications, pick and place processes, or jobs requiring a fourth axis, such as when using a spray valve.
Along with robotics, Fisnar offers an ever-expanding line of robotic accessories to help you get the most out of your robot. Options like tip alignment kits and tip alignment modules help keep dispensing needles in place when switching between materials or tip types. Tip and needle types include tapered tips, PTFE tips, needle tips, blunt end tips, and stainless-steel tips – all with luer lock fittings. A range of nozzles and cartridges are stocked for larger volumes of liquids, including retainers, adapters, pistons, caps, and barrels.
After choosing your robot and accessories, dispensing valves are a crucial component to completely your dispensing system. Not sure which valve is the right fit for your dispensing system? By determining your desired fluid viscosity, fluid content, and application type, Fisnar can identify the best choice for the job. We offer spool valves for high viscosity materials, poppet valves for smaller shots sizes, diaphragm valves for volatile fluids and UV resins, pinch-tube valves for volatiles and cyanoacrylates, needle valves for dots, and auger valves are for high viscosity fluids such as solder paste applications.
We offer FREE robot video trial services to ensure end user accuracy. You’ll get a first-hand look at the process to ensure everything works to your expectations. To learn more about improving your process with Fisnar, visit our website or contact us at info@fisnar.com.
Fisnar®, an Ellsworth Adhesives company, is a leading international manufacturer and supplier of precision fluid dispensing and handling solutions. With over 45 years of knowledge of the dispense industry and its global requirements, we have a wide range of dispensing products and services including robots, valves, dispensers, and a complete selection of consumables.
Armed with technical expertise and a diverse portfolio of dispensing products, Fisnar provides turn-key solutions to suit every budget, application, and industry. We supply everything from simple hand or bench dispensers, to highly advanced automatic robotic dispensing systems. Pumps, reservoirs, and a complete line of consumables. By choosing Fisnar fluid dispensing products, you’ll be confident in the precise application of assembly fluids, ensuring reduced rejects and high product quality.
Fluid dispensers provide precise control during application, available in both manual and automatic options depending on the type of assembly process. Fisnar fluid dispensers are designed to work with a variety of substrates including adhesives, cyanoacrylates, UV resins, silicones, RTVs, and anaerobic materials.
Our newest fluid dispenser is the DC50, a general-purpose, compact, low-cost option that’s easy to use and suitable for both low and high viscosity fluids. It provides high reliability, repeatable dispensing, and adjustable vacuum suckback control, as well as two modes of operation: manual and timed mode.
The DC50’s industry standard air-output connector ensures universal compatibility with syringe adapter heads.
ESSENTIALS
