ASSEMBLY ESSENTIALS
The new PowerStrip 9580 and MegaStrip 9680 systematically continue the Schleuniger Group’s range of versatile automatic cut & strip machines. The machines impress with their exceptional processing range; wires and cables with cross sections up to 70 mm² can be processed with the PowerStrip 9580 and up to 120 mm² with the MegaStrip 9680 – with the optional boost function, between 240 to 300 mm². Powerful servomotors ensure high feed rates and pull-off forces. All motors are equipped with encoder monitoring to immediately detect if the axes are blocked or their position is lost.
To raise your production output to an even higher quality level, all machine versions equipped with a multiblade cutting unit can be upgraded with the SmartDetect quality-monitoring system that inspects the cutting and stripping process of both cable ends in real time, detects all contact between the stripping blade and the inner conductor and allows individual tolerance adjustments for each processing layer via S.ON software. Smooth production processes, fast troubleshooting procedures and minimal material waste are guaranteed! But that’s not all: To make the operation and handling of our new cut & strip machines easier and more efficient than ever, all versions are equipped with intuitive S.ON software, have a color touch screen and come with numerous preset standard values as well as freely programmable material and process libraries to ensure short programming times.
Our two new masterpieces feature an ultra-modern safety concept virtually eliminating the risk of operator injuries. And they can be connected to the manufacturing execution system CAO from DiIT and thus integrated into a network.
Both machines are available in various basic configurations, incorporating a retrofittable and modular machine concept, which allows them to be adapted to your production requirements and integrated into your production processes at any time.
ESSENTIALS
