PRODUCT SPOTLIGHT
This special advertising section is your opportunity to quickly review assembly equipment, tools, components and services that you can use to make your product assembly operations more productive and profitable.
The AGV provides 50-course 128-command control, programming. The AGV is a model HA-A50060 single-direction AGV drive unit with 90° and 180° spin/turn capability. The unit can travel with speeds up to 164 fpm (50 M)/min and can carry a load capacity of up to 1320 lb.
Creform Corporation
800.839.8823
SCsales@creform.com
www.creform.com
AGV system with powered conveyor help increase productivity.
Effortlessly strip coaxial cables, stranded wires, or multiconductor cables with Schleuniger’s new Strip Series B240. Equipped with two rotary blades, it delivers fast and accurate results every time. Its user-friendly, cutting-edge software simplifies the programming process. For any project demanding superior stripping quality and efficiency, the B240 is the optimal solution.
Schleuniger
(603) 668-8117
www.Schleuniger.com
Precise and Intuitive Coaxial Cable Stripping Machine
Sprinter dot marking machines can apply “dot” codes to products after testing up to 350 CPM. Ink dries in seconds and is available in rainbow of colors.
Sprinter Marking Inc.
740-453-1000
sales@sprintermarking.com
www.sprintermarking.com
Pass/Fail Marking System
TorqTec offers a complete line of DuPas torque control power assembly tools: • Cordless Battery Pistol Hydraulic Pulse • Geared Special Attachment Hydraulic Pulse • In Line Pulse • Pistol Pulse • Right Angle Pulse • In Line Screwdrivers • Pistol Grip Screwdrivers (Pneumatic & Cordless) • Right Angle Screwdrivers (Pneumatic & Cordless) • Error Proofing / Poke Options • Traceability Capabilities
TORQTEC
919-561-5536
info@torqtec.net
www.torqtec.net
DuPas Torque Control Power Assembly Tools
With their innovative design, COVAL's CVGC carbon vacuum grippers correspond perfectly to the demands of collaborative robot applications.The CVGC series stands out with a compact, light, strong carbon structure, collaborative safety measures, a choice of gripping interfaces, with or without an integrated vacuum generator. It is easily incorporated on your robot guaranteeing a fast setup
Coval Vacuum Technology
919-233-4855
contact-us@coval.com
www.coval.com
New Generation Collaborative CVGC Carbon Vacuum Gripper
Boulware Equipment, LLC is 100% committed to repurposing industrial wood waste. We convert industrial wood trash into a valuable product and have a nationwide network of wood fiber buyers who rely on our systems supply of predictable quality.
We deliver our clients a reliable “Turn-Key” wood waste solution for almost any pallet / crate & industrial wood waste problem in manufacturing and assembly industries. We offer our systems nationwide.
704-651-6061
brad@boulwarellc.com
boulwarellc.com
Boulware Systems Keep Wood Trash Out of Landfills
IPS robot bases, pedestals and machine tending solutions offer superior quality, stability, and rigidity, as well as exceptional mounting support compatibility. IPS engineers are always ready to discuss a fully optimized and customized solution designed to help you “frame the future” of your robotic work environment.
Industrial Profile Systems
888-729-4500
sales@industrialprofile.com
www.industrialprofile.com
Collaborative Robot Solutions From IPS
The RACO LM Series is a lightweight positioning actuator, which can be easily configured into a wide variety of multiple axis motion systems. The LM is engineered for a load capacity of 800 lbs., speeds up to 200 inches per second, and a stroke range of 20 feet with a single extrusion.
RACO International, LP
(412) 835-5744
(412) 835-0338
Toll Free: (888) 289-7226
raco@racointernational.com
www.racointernational.com
LM Series Actuator
740-453-1000
Looking to improve the quality and efficiency of your assembly with less workers?  Fusion Systems Group has the answer!  We transform manufacturing processes into turnkey automation systems, providing years of cost-efficient production.  Ready to learn more?  Please visit our website for examples of our automated systems.
(440) 946-3300 / (800) 626-9501
info@fusionsystemsgroup.com
www.fusionsystemsgroup.com
Automated Robotic Assembly, Brazing & Dispensing Machines
TORQTEC
919-561-5536
info@torqtec.net
www.torqtec.net
COVAL's CMS HD series of multi-stage heavy duty vacuum pumps for industry specific applications resulted from many years of feedback from manufacturers, integrators, and users across multiple industries. The CMS HD meets expectations in terms of power, robustness, ease of use, and modularity, while remaining compact and light for simplified integration in a smart factory.
COVAL Vacuum Technology
(919) 233-4855
info@coval.com
www.coval-inc.com
CMS HD Series: Multi-Stage Heavy Duty Vacuum Pumps
March 2025 | Vol. 68, No. 3
