PRODUCT SPOTLIGHT
This special advertising section is your opportunity to quickly review assembly equipment, tools, components and services that you can use to make your product assembly operations more productive and profitable.
Sprinter dot marking machines can apply “dot” codes to products after testing up to 350 CPM. Ink dries in seconds and is available in rainbow of colors.
Sprinter Marking Inc.
740-453-1000
sales@sprintermarking.com
www.sprintermarking.com
Pass/Fail Marking System
The X-PAQTM precision fastening system provides precise torque control, maximized operational efficiency, and real-time data monitoring for assembly processes. Its user-friendly interface, reliable performance, and connectivity options streamline operations, improve quality, and reduce downtime, making it an essential tool for efficient and accurate manufacturing.
ASG, a Division of Jergens, Inc.
asginfo@asg-jergens.com
asg-jergens.com/precision-fastening/x-paq-sd2500/
ASG X-PAQTM: Controlled Precision, Accuracy and Traceability
740-453-1000
740-453-1000
The HE-490S ATEQ Helium Leak Tester offers precise and reliable helium detection for critical applications. In addition to the HE-490S, ATEQ provides a comprehensive range of leak testing instruments, including air leak testers, hydrogen/helium, and argon leak testers, ensuring top-tier solutions for diverse industrial needs.
ATEQ Corp.
(734) 838-3100
atequsa.com
sales@atequsa.com
ATEQ HE-490S Helium Leak Tester
Effortlessly strip coaxial cables, stranded wires, or multiconductor cables with Schleuniger’s new Strip Series B240. Equipped with two rotary blades, it delivers fast and accurate results every time. Its user-friendly, cutting-edge software simplifies the programming process. For any project demanding superior stripping quality and efficiency, the B240 is the optimal solution.
Schleuniger
(603) 668-8117
www.Schleuniger.com
Precise and Intuitive Coaxial Cable Stripping Machine
The RACO LM Series is a lightweight positioning actuator, which can be easily configured into a wide variety of multiple axis motion systems. The LM is engineered for a load capacity of 800 lbs., speeds up to 200 inches per second, and a stroke range of 20 feet with a single extrusion.
RACO International, LP
(412) 835-5744
(412) 835-0338
Toll Free: (888) 289-7226
raco@racointernational.com
www.racointernational.com
LM Series Actuator
740-453-1000
Looking to improve the quality and efficiency of your assembly with less workers?  Fusion Systems Group has the answer!  We transform manufacturing processes into turnkey automation systems, providing years of cost-efficient production.  Ready to learn more?  Please visit our website for examples of our automated systems.
(440) 946-3300 / (800) 626-9501
info@fusionsystemsgroup.com
www.fusionsystemsgroup.com
Automated Robotic Assembly, Brazing & Dispensing Machines
TorqTec offers a complete line of DuPas torque control power assembly tools: • Cordless Battery Pistol Hydraulic Pulse • Geared Special Attachment Hydraulic Pulse • In Line Pulse • Pistol Pulse • Right Angle Pulse • In Line Screwdrivers • Pistol Grip Screwdrivers (Pneumatic & Cordless) • Right Angle Screwdrivers (Pneumatic & Cordless) • Error Proofing / Poke Options • Traceability Capabilities
TORQTEC
919-561-5536
info@torqtec.net
www.torqtec.net
DuPas Torque Control Power Assembly Tools
COVAL's CMS HD series of multi-stage heavy duty vacuum pumps for industry specific applications resulted from many years of feedback from manufacturers, integrators, and users across multiple industries. The CMS HD meets expectations in terms of power, robustness, ease of use, and modularity, while remaining compact and light for simplified integration in a smart factory.
COVAL Vacuum Technology
(919) 233-4855
info@coval.com
www.coval-inc.com
CMS HD Series: Multi-Stage Heavy Duty Vacuum Pumps
September 2024 | Vol. 67, No. 9
